I think I bought the wrong flywheel?
Old December 7th, 2012, 12:59 PM
j_link's Avatar
I ordered the below flywheel for my auto to manual conversion from Rockauto. It says it fits '71 350 Olds, so I thought since all the research I have done says the factory flywheel is the same from '68 and up for big block and small block I should be good. I spent 10 minutes under the car and though it looks close I don't think it is going to fit. Thoughts?
http://www.rockauto.com/dbphp/mak,OL...,5348,Flywheel
j_link is offline
Old December 7th, 2012, 01:08 PM
Run to Rund's Avatar
1. 168 teeth is Chevy; 166 is Olds
2. Olds mounting bolts are arranged so it bolts up only one out of six potential ways.
3. I refuse to use cast iron grenade flywheels, especially Chinese cast, because my feet are discontinued.
Run to Rund is offline
Old December 7th, 2012, 01:12 PM
j_link's Avatar
Great, nice of them to list it as an Olds part. I know they were not putting Chevy 350s in Cutlass in '71.
Understood on the quality of the part. I have no intention of drag racing my car though. I guess I will have no choice other than upgrade to the SFI flywheel other than going used.
Thanks for the info on the tooth count.
j_link is offline
Old December 7th, 2012, 02:20 PM
Octania's Avatar
Huh, 1968 442 engines included a 350, 400, and 455
http://www.rockauto.com/catalog/rafr...%2BFlywheel&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=o685qh5m5adcn3qav1eme65l60
BULLSHED !!
I see there is an option to create a login and add expertise.
No flywheel listed, not under Engine or Transmission, for the 1968 400 engine 442 model.
Octania is offline
Old December 7th, 2012, 07:36 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Send it back. Rock Auto has good customer service and it's their mistake. The 'wheel they list is incorrect for any Olds V8.
copper128 is offline
Old December 7th, 2012, 09:34 PM
costpenn's Avatar
Just went through his myself. I believe you probably got a PE-100 flywheel from Pioneer (made im Mexico) It's wrong - the bolt pattern doesn't line up no matter how you turn it.
costpenn is offline
Old December 8th, 2012, 01:17 PM
One more time, vendor catalogs, particularly on-line ones, are notoriously incorrect for older cars. As an example, RockAuto shows that Vista Cruisers use B-body ball joints, not the correct A-body ball joints.
joe_padavano is offline
oldcutlass
November 12th, 2013 02:30 PM
marinus_
August 23rd, 2009 08:00 PM
alan69delta88
August 17th, 2006 02:13 PM
Quick Reply: I think I bought the wrong flywheel?
