Hydo
Old Oct 10, 2007 | 12:25 PM
STEVE1103's Avatar
Hydo
Friend has a 40, can't get it in reverse, engine and trans was out of car, now we have this trouble. Is there a procedure for adjusting the shift rod? Thanks
Old Oct 10, 2007 | 01:49 PM
dar83501
Guest
Posts: n/a
are you sure the transmission's not blown and needs a rebuild?
Old Oct 10, 2007 | 05:00 PM
STEVE1103's Avatar
Will move foward, in each gear!
Old Oct 10, 2007 | 05:08 PM
dar83501
Guest
Posts: n/a
that doesn't mean anything. transmissions can blow individual gears, I have one sitting in the shop with no 2nd gear...
Old Oct 10, 2007 | 11:01 PM
88 coupe's Avatar
Junior Member
Originally Posted by STEVE1103
Friend has a 40, can't get it in reverse ........
Feel like something is blocking it? Make sure the idle speed is under 450 RPM.
........ Is there a procedure for adjusting the shift rod?
http://edge-op.org/1949_Oldsmobile/images/334.jpg
http://edge-op.org/1949_Oldsmobile/images/335.jpg
http://edge-op.org/1949_Oldsmobile/images/335-1.jpg
From a '49 manual, but it's the same trans.
Norm
