Hurst Dual Gate added to a '73-'77 Console
Old Apr 23, 2023 | 06:28 PM
goatwgn's Avatar
Have any of you ever installed the Hurst Dual Gate with the standard shifter console in the '73-'77 Cutlass? Curious what modifications you had to do to the console. If I do this, I want it to look like the way it was installed on the Hurst Olds. I am thinking I'll have to cut part of the console out.
Old Apr 24, 2023 | 06:05 AM
Your biggest problem will be finding the correct top plate.
Old Apr 24, 2023 | 07:52 AM
rocketraider's Avatar
Oldsdruid
Correct. Console has to be cut to install the D/G.
The plastic top plate was reproduced many years ago because of the "finger's" tendency to break out of it, but I don't think the guy is making them any more. The one I got from him came "as molded". As in no plating or paint. I never did the conversion because of that.
You're aware the 73-77 Dual/Gate requires its own specific shift cable, right? Grp 4.047 p/n 417536. The standard floorshift cable doesn't work.
Old Apr 24, 2023 | 09:13 AM
goatwgn's Avatar
It appears as if they sell a complete Hurst Dual Gate, to fit the '73-'77 for about $600. With the top plate, cable, etc.
Old Apr 24, 2023 | 09:51 AM
75 W-30 H/O's Avatar
Here's the top plate...
https://www.ebay.com/itm/33078112564...mis&media=COPY
Old Apr 24, 2023 | 09:57 AM
And the whole shifter. OPGI carries them too...
https://www.ebay.com/itm/35094809537...mis&media=COPY
Old Apr 24, 2023 | 12:35 PM
Oldsdruid
Hmm. Looks like a lot has changed since I was considering the D/G for my 74 350 Hurst. Looks like all I need to get is the top plate. I have the shifter, an NOS cable and a spare console.
The D/G was originally available only with the 455/Turbo 400 and requires some type of cable bracket on the transmission pan to use it with a Turbo 350. Anyone know if that's being reproduced?
Old Apr 24, 2023 | 12:46 PM
I suspect the 1969-72 TH350 bracket is the same.
EngineErnie
Mar 23, 2020 07:53 AM
BeenThere
Jul 8, 2017 07:53 AM
anthonyP
Jun 16, 2016 10:39 AM
Big Dawg
Drivetrain/Differentials
May 11, 2016 05:06 AM
brettharmon
Sep 6, 2010 05:43 PM
