How much oil
Old Apr 15, 2014 | 05:49 PM
rodan's Avatar
How much oil
How much oil do I put into a a fresh rebuilt turbo 350 and in the converter?
Old Apr 15, 2014 | 06:00 PM
A LOT.
I don't recall exactly, but it's something like 12 quarts.
What will happen is that you'll fill it up to where it just touches the bottom tip of the dipstick, and you'll think, "Just one more quart to go," and you'll add another quart, and the level won't move, then you'll add another, then another, then another, and you'll keep looking underneath for a leak, because there's no way all of that ATF is still inside there, but sooner or later, usually after you have stopped checking carefully, you'll overfill it, and then curse as you try to suck it out through the fill tube.
molasses4masses
Jan 13, 2014 10:04 AM
BradyB
Sep 25, 2012 09:03 AM
jasmit29
Sep 14, 2012 08:34 AM
RayJ
Sep 12, 2012 04:44 PM
