help me identify this please
Old Aug 16, 2012 | 11:24 AM
lowkey235's Avatar
1966 toronado barn find. it is connected to the throttle linkage and wired to the transmission. My guess is its a transmission kick down. doesnt show up on my wiring diagram shows up in the transmission section of my manual refered to as the stator..but cant find anything else. what is it and what would the symptoms of it failing be...looks like mice have been at the wiring.
Old Aug 16, 2012 | 04:46 PM
BILL DEMMER's Avatar
Just the facts...
that's the throttle bellcrank assembly. it also has the kickdown and torque converter pitch switches inside.
bill
Old Aug 16, 2012 | 05:31 PM
lowkey235's Avatar
Thank you sir.
Old Aug 17, 2012 | 11:06 AM
Just the facts...
yw.
no need to call me sir
bill
Old Aug 17, 2012 | 11:30 AM
OldsMotion's Avatar
OldsMotion
Ah, part of the workings of the "switch pitch" transmission??
John
Old Aug 17, 2012 | 11:38 AM
rocketraider's Avatar
Oldsdruid
It controls electrical downshift on a TH400 as well as torque converter stator angle on a switch-pitch. Used 65-67. One switch used on 88/98/Cutlass, another on Toronado. There are standard and trailer towing versions of each.
Two obvious symptoms if it's bad or out of adjustment: 1) trans will not downshift and 2) off-the-line performance will be sluggish due to wrong stator angle. Right now I can't remember whether it's stuck in high angle or low angle that causes poor off-the-line acceleration.
Old Aug 17, 2012 | 12:58 PM
lowkey235's Avatar
found this at 442.com not sure of its accuracy...
To summarize:
Apply 12V ==> hi angle, high performance
No signal ==> low angle, better economy
Old Aug 17, 2012 | 10:57 PM
Just the facts...
John
that's the facts, jack! (juan)
bill
Old Aug 17, 2012 | 10:59 PM
Just the facts...
also, switch pitch was to reduce a vehicle's tendency to "creep" requiring a lighter foot on the brake when stopped for a stoplight, etc.
bill
keiperrc
Sep 17, 2014 09:14 AM
AK71CutlassS
May 28, 2014 07:16 AM
JJSCUTLASS
Oct 23, 2012 04:05 PM
Rick E
May 12, 2012 07:12 PM
oldsrocket88
Mar 1, 2012 11:38 AM
