front seal look good?
Old Mar 11, 2014 | 02:53 PM
Macadoo's Avatar
Hey folks,
Finally got some time in the shop. Some "above zero degrees" time!
I pulled the tc and finally got a look at the front seal that was supposed to have been replaced when I bought the car. It seems rubbery and flexes when touched. It does seem that since I'm there I should just replace it. Is that a tough job? Just yank out the old and push in the new?
[IMG][/IMG]
[IMG][/IMG]
Also, uhh...I pulled a boner and couldn't resist scraping some of the grit off the top of the tranny....with the tc laying underneath. And yes, with the opening pointing up, D'OH! Any way to clean that out? I don't think it got much in there but even a little would be, I assume, bad.
Old Mar 11, 2014 | 02:58 PM
It's hard to tell, but I'll assume its good as there isn't a bunch of oil and crud in there and no sign of a leak.
Old Mar 11, 2014 | 06:33 PM
Looks clean, doesn't appear to have been leaking in the past.
If you do decide to replace the seal, knock the old one out with a chisel and pry bar. Pack the inside of the new seal with Vaseline. Its pretty easy to knock the small garter spring out of the seal when driving it in. The Vaseline will hold the spring in place, and will provide plenty of lube when starting the trans for the first time. Don't use wheel bearing grease, it wont dissolve in the trans fluid.
Old Mar 12, 2014 | 12:52 AM
nsnarsk65cutlass's Avatar
It's a MAW imho, it is a lot easier to do now or find out later after all is up and running and leaking,do as matt69olds stated .Nick
Old Mar 12, 2014 | 06:13 AM
Macadoo's Avatar
Might be worth the $4 to have some peace of mind. Thanks for the tips, matt.
Joffroi
Nov 27, 2010 04:11 PM
1983oldsmobiledelta
Sep 27, 2010 05:43 AM
delta881972
Mar 5, 2010 10:52 AM
old98owner
Drivetrain/Differentials
Feb 2, 2009 02:03 PM
Sixoh
Aug 8, 2006 05:11 AM
