Four speed automatic question
I currently own a 1965 cutlass with a 330 ci. I have a 2 speed jet away but would to convert it to a four speed transmission. How do I find out what the best fit would be. I am looking for a daily driver with a little get up.
The 200-4R is the same overall length as your current Junkaway, er, Jetaway trans. The driveshaft stays the same and the trans bolts directly to your 330.
Two things to keep in mind are 1) the crossmember will need to be moved rearward to the TH400 position and 2) you'll need a TV cable. Since the TH400 wasn't offered on the 1965 cars, you'll need to drill holes in the lower frame rail for this new location. Later cars had the holes from the factory for the optional TH400. Moving the crossmember also means that the e-brake cables are different, since they hang off the crossmember. Get the front and intermediate cables for a 1967 442 with the same body style as yours. Rear cables stay the same. The TV cable is probably easiest if you use an aftermarket setup, like Lokar.
He may need to put a note on the dash, to himself, to not try and hold it in low until 90
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
I was thinking how smooth, and fast the shifts can be just cruising around, and it is a very quiet tranny. The noise level at higher speeds will be much lower and quieter than what he is use to as well. It will be like a new car to them.
Any 2004R built after 1984 alreqdy has all the factory hardened internals. For that matter, the 2004R in grandma's Cadillac is identical the the trans in a Buick Grans National, with the exception of the valve body, govenor, and servo. In other words, if the trans is in good mechanical condition, a good shift kit is probably all it needs to live behind a stout small block. Make sure the TV cable is adjusted right (close is not good enough!) And enjoy the best of both worlds, the added acceleration of the lower gear,(tje car is going to feel lime you added 75 horsepower) and the added fuel economy and comfort of the overdrive.
Hardened pump rings, stiffer spring, hardened stator and the big Transgo shift kit should do it. Over fill it a quart or buy the Hughes deep pan which now comes with the bottom feed 700R4 filter. The stock fiter sucks from the top, a poor design for hard launches.
Now I've got to go find out - I recall he M21 in the Chevelle I had as a kid having a TH400 yoke - I know because when I swapped in a T-10, I had to change the yoke... Or at least I think that's what I remember.
Check out www.tvmadeez.com and be sure to get that tv cable installed and adjusted correctly. VERY IMPORTANT!
Also http://www.tvmadeez.com/article/index.php
Wil Lopez
Ninety-Eight
August 29th, 2010 09:41 AM
