Flywheel bolt pattern?
I am going to do a 200R4 conversion this summer in my 65 with a 330 300ST. I've not seen it stated anywhere as to whether the torque converter bolt pattern on the flywheel is the same for these too different transmissions. I assume they are the same but you know what they say about assumptions.
I've got both the 330 flexplate and a 200R4 transmission. If someone else doesn't speak up first I can try holding the flexplate against the torque converter to see if they will match up. John
Nailhead 88
November 19th, 2008 08:21 AM
