to flush transmission or not to flush?
Old Feb 15, 2008 | 12:56 PM
cola's Avatar
Hi everyone
I have a 68 cutlass s that I picked up a little while ago. The car has been sitting for about 7 years. It has been started and moved up and down the drive way but no further. I wondering if I should have the tranny flushed in the spring and have the gasket and filter changed? I've heard several opinions. One no because this will loosen up any deposits and possibly cause damage. Second similarly the new oil will cause the same thing to happen. Anyone have any thoughts on this?
Old Feb 15, 2008 | 01:18 PM
The_Jeremiah's Avatar
Well with a new filter, those deposits will break loose, and get stuck into the new filter, I would recommend it, because the fluid starts to break down. and if the filter is clogged, every time your run it, your running dirty fluid through the transmission, over time that will cause more damage than anything.
Old Feb 15, 2008 | 02:38 PM
rrielley's Avatar
I would have to agree with the Jeremiah. I have heard this ridiculous theory before that it is better to NOT change really old engine oil or transmission fluid. That is a rubbish idea! Old oil/fluid is bad. New oil/fluid is good.
Old Feb 15, 2008 | 02:54 PM
cola's Avatar
to flush tranny
Hi everyone
I thought the same thing. That oil's been sitting for probably 39 years. I can't see that being good.
cola
Old Feb 15, 2008 | 03:49 PM
That is a very bad thing. Even if flushing out the old fluid causes debris to break loose it wouldn't harm that transmission. I have never heard of a TH 350 or TH 400 failing from old age. Towing, racing, bad / no fluid, or overheating but not old age.
Old Feb 15, 2008 | 09:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You wouldn't believe the awful chunks of garbage that I've pulled out of my pan. Change your fluid often, mine always has crap dropping out of it, but always keeps on going
Old Feb 15, 2008 | 10:12 PM
shaks 442 clone's Avatar
i've heard in new cars changing very old trans fluid can cause slipping
infact my buddy who works at oil changers just changed his trans fluid out and guess what
the second he went to floor it guess what he was doing about 5 mph and slowly rising to about 10mph then it wouldnt go any faster
but i have never heard anything about the turbo 350's or 400's
Old Feb 15, 2008 | 10:13 PM
by the way he has a 89 ford mustang if anybody was wondering
Old Feb 16, 2008 | 09:01 AM
Mine feels like it's slipping for a while, after every time that I change fluid.
I always put the lucas additive in a few days later once it's used to the new blood, and then it drives just fine for another 30,000 miles.
Old Feb 16, 2008 | 10:27 AM
haha the lucas additive works miracles
i put some in a trans that was slipping a 93 isuzu trooper and the slipping totally went away for the first hundered miles then it came back
once it was time to sell it guess what went right back in the trans lol
jpc647
Sep 5, 2016 01:46 PM
jtriggy
Brakes/Hydraulic Systems
Apr 19, 2010 05:01 PM
marinus_
Aug 15, 2008 01:58 PM
a6m5zerosen
Jan 3, 2008 02:57 PM
ztim
Dec 13, 2007 05:07 AM
