floor shifter question, 71 cutlass
Old Apr 8, 2008 | 06:02 PM
cruznn's Avatar
Hi
Does anyone know how to get the lever you lift up on to change gears off of the handle. I need to remove it to install the shifter seal that slides back and forth when you shift to different gears. Its the part below the shifter ball that looks like a tee.
Thanks,
Mike
Old Apr 10, 2008 | 01:28 PM
70oldsW30's Avatar
There's a little allen screw that holds it on.
Well, if I remember right. It's probably been eight years since I had one in front of me.
Old Apr 25, 2008 | 05:40 AM
silverriff's Avatar
1972 Cutlass 455
Its been a few weeks since your post, but I had to do this this past weekend on my 72. Mine had a pin that I had to stick a very small screwdriver into and bang it out. If you haven't done it already, hope that helps!
-Eric
harleyrules
Nov 9, 2025 06:52 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
mryoung4815
Apr 14, 2009 02:13 AM
olds4life
Feb 27, 2009 08:54 PM
harleyrules
Nov 3, 2007 03:47 PM
