EEK!!! no likey this noise
#41
Sicky, I wish I could justify the drive to SA...I would love to hear it in person. The chirping noise is what gets me, if it was knocking it would be a deep thud sound. It would also get faster as rpm increased, not go away as you suggested.
It's odd that it won't stay running without giving it gas...what heads are on it? Did you have new valve guides put in it? You said it sounds like every other rotation, like when an exhaust valve or intake valve opens / closes. Might a bent pushrod scraping the head cause that noise as well? I believe I would pull a valve cover and rockers off and start looking there...but again, I'm not hearing it in person.
#43
Here's something way out in left field, but it's possible. I took a 76 455 off the road for a knock that turned out to be this.
Pull the fuel pump and see if the lever is worn or looks like it's been dry. If the timing chain area isn't getting lubed thru the orificed plug, the fuel pump eccentric could be running dry and causing all this chaos.
#45
And at ah64, we used a cam that another member had with his lifter combo (dont worry the lifters were put in the exact same way they were to the cam). The cam weused MAYBE had 5k miles on it....
#46
Just got done draining the oil. Seems to be fine, no metal chunks or anything like that. color looked good same as consistency, Ruling out the spun bearing.... for now, Will probably start taking off the intake manifold to check out the push rods and see if i can see the cam bearings with it off
Keep the ideas coming in guys, this one is baffling people that is for sure
#47
Well last time we did it it seemed to get faster with the RPM not quieter. And there are people here in SA that are helping that are in the club but they have there own broken down messes lol.
#48
Where can you buy those all I can ever find is the quiet ones.
I hope you figure this out and its simple but it does not sound good at all. You need to cut you oil filter apart and look for any metal. The squeak and fact that it wants to die at idle is a bad sign. Really sounds like a bearing to me.
#49
Well here is what a buddy of mine from high school thinks and it kinda makes sense to me... what you guys think
Quote
Ya sounds like a compression leak to me either head gasket or intake gasket the exhaust port in the intakerunner for crossover.
This would explain the oil leak i have as well that i have been having
Quote
#50
Listen to Richard before you turn the engine over again. It takes 15 minutes & $10 for a decent filter to confirm that there's no metal in there
#51
I agree with gearheads...cut your filter apart and then use a magnet to collect metal from the oil that is in the filter. Also look at the filter element for metal shavings.
If this was a compression leak it wouldn't be this loud. No offense to your friend but you'll never know if there was a leak between cylinders, it would just have no power. You can do a compression test on it but it will only tell you that it is NOT a head gasket leaking.
It's only work to pull the engine and check out the bottom end...might take you 2 days, but at least you'd know for sure and be able (possibly) to make the cruise in October.
#52
Oh i am going on that cruise lol. if i have to i will be taking the caprice, but the 70 SHOULD be here by then and we shall see how that one is also lol
#53
Listen to the sound while under the side of the car...if it gets louder then my guess is some interference with Flexplate and or Torque Converter. Really doubtful its internal to the engine...bearings don't normally " squeek "...
Let me know
Danny
Let me know
Danny
#54
I didnt know you were on these forums MAN!!!! You are always welcome to come over an take a look at it . Wanna see if i can get it up and running/fixed so i can run it at the BOP shootout. So i am hoping for the sake of not pulling the engine apart it is the freaking flexplate or torque converter....
#55
So i got under the car and took a jab at it, quite literally and i noticed i have Bronze itty bitty flakes in my oil?
Thoughts and here is a pic of it leaking out, you can see the stream in it for the color=
#57
Danny (79WCars) came over and looked at the engine and we decided that it was an internal problem, so today i pulled off the intake manifold and this is my findings...
The flake that i took a picture of is a piece that i pulled out of the valley. You can see another one in another picture also.
#59
Wow that's crazy man. I've wiped out lobes before, but never had a noise like that just the rattle from a loose rocker. That one lobe looks dry. I would suspect that you are going to find a spun cam bearing that has sent debris into the oil passages.
#60
I just ran across this post. This sounds exactly like my engine when I spun a rod bearing. It has happened twice and both times it sounded the same. On my engine the bearings overlapped and that caused it to be tight on one side causing the squeal. It sounds kind of like a slipping belt but deeper in the engine. If you found copper in your oil it is probably from the bearings. Hopefully this is not the case but it sure sounds like and as it gets tighter the harder it will be to keep your engine running at idle.
#62
on to another rebuild....
#63
Well... The guy who rebuilt the engine was me and a buddy in my garage... So can't ask for a free fix on that. Just seems weird cause I almost put 1k on the motor and you would think it wolff have happened before that? But the guy who machined it def did. He does everyones motor in the club
#64
1k into thewhole engine ? did you just do a simple re ring and bearing with fresh gaskets and new cam. With machining i would expect it to be over 1k into the bottom end i have almost 1k into mine and i polished the crank my self and honed out the cylinders . what brand bearings did you use .
#65
#67
@ firefrost i didnt see aything noting money or miles lol my bad . but that sucks bout the engine none the less hope its not too bad and it can be corrected without spending lots of money .
#68
I have followed this tread and car . I talked to the guy he got it from and was looking at it myself. Wrong time , wrong car but was thinking of making a offer
Still have some photo's that i was sent on my pc.
#69
ACTUALLY it was both 1k miles and around 1k as well. Had the machine shop hone 4 and resleeve 4 cylinders, polished crank and got a re-ring kit and gasket kit and we did the rebuild in my garage. Parts were still good that we put back in, and put a new (used) cam in there as well, only had about 6k mileage on the cam from before.
Not sure what bearings brand was used,threw the box away, maybe the receipt says, but the machine shop ordered them for me as well so i would have the right size.
#70
Stalker LOL but igot to admit, not sure how this fits in here Firefrost, so i am just curious on why you said this lol
#72
#73
will talk to you on FB with tuesday, talking to you right now actually and i am not sure if i will be taking the 70 on the cruise, need to find out why it is stalling on me lol, getting a q-jet rebuilt though,but we shall see
#74
when you get into this thing check your crankshaft thrust... the fact that it(noise) seemed to start at the rear of the engine and then you find copper flakes as opposed to silver colored debris in the oil makes me wonder about the crank thrust... the odd thing is that it ran fine for 1k miles... maybe some crud got loose somewhere and blocked an oil passage?
gibbo69olds
October 3rd, 2007 06:39 AM
