Dust Cover
Old Jul 16, 2013 | 04:10 PM
ollerich29's Avatar
Dust Cover
I have a '70 cutlass supreme, and I have a tranny oil leak from the torque converter dust cover. My question is it normal to have oil inside the dust cover? If I put a new cover on and stop the leak should I be concerned about leaks elsewhere?
Old Jul 16, 2013 | 04:24 PM
No, it's not normal. The dust cover is just that a dust cover. If you have trans fluid in it it's leaking from the trans.
Old Jul 16, 2013 | 05:15 PM
Lady72nRob71's Avatar
And if it has oil in it, it is leaking from the engine, another abnormalty.
Old Jul 22, 2013 | 08:31 AM
ollerich29's Avatar
ok thank you, it looks like it is just tranny fluid.
Old Jul 22, 2013 | 09:09 AM
Most likely the seal between the torque converter and the pump. Less likely but possible is the pump-to-case gasket.
fmbjogger
Oct 20, 2010 07:13 AM
jr711
Drivetrain/Differentials
May 31, 2010 03:46 PM
wjustinmartin
Brakes/Hydraulic Systems
Dec 11, 2009 02:24 PM
JSGD1966
Jun 1, 2009 10:50 AM
toneypenna
Oct 5, 2006 02:55 AM
