Downshift Switch adjustment..
Old Jun 7, 2012 | 11:28 AM
Stevec's Avatar
Does anyone know the downshift switch adjustment procedure? I know the switch is by the gas pedal but I can't find the procedure in the service manual.
Thanks.
Old Jun 7, 2012 | 11:52 AM
White Spyder's Avatar
I am just learning a bit about these cars but in other GM applications it is a function of the kick down cable (detente cable) from the carb to the trans. To make changes you adjust the cable length
Old Jun 7, 2012 | 12:14 PM
If it's a T400, it should close at full throttle.
Old Jun 7, 2012 | 12:17 PM
1965cutlassragtop's Avatar
what kind of tranny are you running??
Old Jun 7, 2012 | 01:13 PM
AZ455's Avatar
1974 DELTA 88
Since he said switch, I will assume TH400. If I remember correctly, you can pull the switch to the close position by hand, then let it quickly release. This will reset it, then the next time you push the pedal to the floor it will set itself to the proper position. Unfortunately there is no other adjustment for a TH400 kickdown, only works at WOT.
Austin Trevor White
Apr 2, 2013 12:46 PM
brown7373
Mar 27, 2013 11:41 AM
metalmen
Feb 4, 2013 05:26 PM
sammy
Jan 10, 2012 09:45 PM
Dapapadon
Feb 26, 2008 01:37 AM
