Downshift Solenoid Valve Connector
Hi everyone! I was hoping for some help in identifying and locating parts for the THM400 in my '68 Delmont (455) and for some "How to" help. I am going to change the ATF filter next week and while the ATF is drained, I also want to remedy a leak I have at the location where the connector that controls the (detent) downshift valve connects into the transmission. In Ron Sessions' book, I think I have identified the key part: Connector to Case Seal (p/n 6264903). Does anyone know where I might find this part? And do you think I should replace all the seals (which probably have never been done) while the ATF is out for the filter change? None of the other connections are currently leaking although I did get ATF blowing out of the filler tube - but I think cleaning the vent cured that problem although I will keep my eye on that.
Has anyone done this connector seal change? And perhaps might let me know what steps should be taken - even on how to remove the connector?
Thanks!!
Thanks!!
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
It looks like I may have found some information about this connector. It looks like the downshift solenoid connects to a single pin connector that runs through the trans case on the driver's side. In order to replace this connector, I am going to need to remove the pan to get access. I still don't know what size O-ring or grommet I am going to need. I should be able to figure that out once I have the old connector out. For the THM400 I have, I ordered a new connector and some various O-rings and grommets.
84oldsDelta88
January 19th, 2010 11:04 AM
