Doing the swap
Old May 20th, 2016, 07:41 AM
LMC
LMC's Avatar
Question Doing the swap
I am going to do a trans swap in my Cutlass S 350 engine. Basic stock with a small RV cam. I am thinking of power glide out and th350 in. Would anyone have any advise on the best Trans and torque converter for that swap. I am not going to hotrod it at all, but would like it to spin the tires once in a while if I choose.
LMC is offline
Old May 20th, 2016, 07:44 AM
First off you don't have a powerglide. If its a 2 speed its most likely a jetaway (St300). The T350 would be a direct bolt in with the only mod being a kickdown cable.
oldcutlass is online now
Old May 20th, 2016, 08:17 AM
LMC
LMC's Avatar
thank you
thank you for correcting me, I did not realize I had to split hairs here to be understood. you are right it is not a powerglide it is a Jetaway. I also have chevy's so it's my mistake. both 2 speed, both GM. please forgive my ignorance.
This is my wife's car she had when she graduated from high school. she ask me to restore it. my wife passed away a year ago Wednesday. the car is now restored but she never got a chance to drive it.
thank you for your advice, I will remember it.
LMC is offline
Old May 20th, 2016, 08:23 AM
Wow, sorry to hear of your wifes passing without getting to drive her pride and joy. The reason I brought up the difference in the 2 speeds is that the ST300 has nothing in common with its Chevy counterpart. When you look for a T350, it has to be a BOP (Buick, Olds, Pontiac) bolt pattern. The torque converter stall is dependent on your cam and rear gears.
Old May 20th, 2016, 08:49 AM
hookem horns's Avatar
This will help too.
http://www.shiftworks.com/cutlas67-72.htm
hookem horns is offline
Old May 20th, 2016, 12:47 PM
LMC
LMC's Avatar
update on doing the swap
I just checked the diff & ratio. If I am correct it is a 2.78 gear (S3) and a anti spin rear end.
LMC is offline
Old May 20th, 2016, 04:57 PM
If its just an RV cam you can probably can consider an 1800-2000 rpm stall. You can probably run a stock converter also.
Old May 21st, 2016, 12:58 PM
svnt442's Avatar
What year is the car?
svnt442 is offline
Old May 21st, 2016, 01:29 PM
He has a 68.
Old May 21st, 2016, 01:42 PM
LMC
LMC's Avatar
dong the swap
it is a 68 cutlass s
LMC is offline
Old May 22nd, 2016, 04:59 AM
65Delta's Avatar
Stock rebuild on a BOP TH350 with a stock converter, good quality frictions, and a shift kit should do nicely. You'll have to get the accelerator pedal for the 69-72 A body with a TH350, kick down cable from pedal to trans, and bracket that holds the shifter cable to the pan (Jetaway one is different). Keep an eye out for a good core on Craigslist or at the junkyard and ask around for a local reputable rebuilder.
65Delta is offline
Old May 22nd, 2016, 06:44 AM
LMC
LMC's Avatar
doing the swap
thank you for the advice 65DELTA. I was thinking of buying an aftermarket trans and torque converter. I am looking at JEG'S trans 60305 and TCI 241502 Saturday night special. would that be in line of what you are talking about.
LMC is offline
Old May 22nd, 2016, 07:45 AM
Both of those should work fine with a relatively stock engine and an RV cam. You can use the Chevy style kick down cable and carb bracket for your application also.
Bracket:
http://www.jegs.com/i/JEGS-Performan...57336/10002/-1
Cable
http://www.oreillyauto.com/site/c/de...3199&ppt=C0333
Carb stud
http://www.oreillyauto.com/site/c/de...1069&ppt=C0261
Old May 24th, 2016, 06:21 PM
LMC
LMC's Avatar
doing the swap
thanks for the advise oldcutlass and thanks for the links, that will help a lot in my project to swap. sorry for late reply, I have been out of town. my wife wanted to restore the car and drive route 66. I am going to take it for her.
LMC is offline
Old May 24th, 2016, 07:06 PM
That will be a great tribute to her with the car. Your quite welcome, hope your swap goes well.
autofluencia
July 24th, 2015 05:49 PM
Oldsguy
November 28th, 2010 12:31 PM
liquidpower
Ninety-Eight
27
March 19th, 2009 11:22 AM
ChrisM
February 7th, 2009 03:47 PM
silverriff
March 16th, 2008 03:38 PM
Quick Reply: Doing the swap
