D'oh and Who-Hoo in one breath
OK I found out today that the tranny hooked up to the motor is a TH 400 and not a TH 350.
The good part is that it's a 400, the bad news is that I bought the driveshaft with the 350 yoke (smacks head, althought my mech wants to do that for me).
There is no speedo hookup
Is it the wheel one, and how do I hook that up to an 1985 Delta?
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
If it is the wheel type one you should see a cable coming out of the front driver's side backing plate but I don't think they still did that in '85. I am working from memory but I think the cable housing attaches on the driver side just above the pan about midway. If you do have the type that required the cable to the wheel you would have to find that whole assembly from a donor car. It would require the spindle with the hole in it and I don't know if the older style would fit on your '85 Delta or not. I bet it could be done but would probably not be easy. Don't forget the bearing dust cap with the cable termination on the inside of it, it sort of looks like a little nut with a square hole in the center that is brazed on the inside of the cap.
Only the output shaft and/or housing.
Good luck!
TH400 Speedo Cable
This thread got me to thinking, and I went out to the trannie grave yard to look at TH400's. I looked at 5 of them with the speedometer cable and they all attach in the main trannie body, not the tail shaft. I also have some of the wheel cable TH400's and looked at one of them. Comparing the two I think Joe's right, that Redog won't be able to use that trannie with any kind of conventional speedometer cable.
The speedo cable fitting bolts into the main trans case, not the output housing. You can unbolt the tail housing, press a speedo drive cable onto the existing output shaft, and reinstall the housing. The problem is the opening in the trans case. If the trans has the hole machined and a plug pressed in, it's easy to retrofit the speedo cable. If the case is not machined, it's a lot of work.
I am going to have to address this issue in my application. The TH400 came from a '69 Delta 88 that used the wheel speedo so there is a hole in the side of the transmission case for that. However the transmission is now in a '46 Olds and I am going to have to find a way to drive the speedo, or go without it and cover the hole so I don't loose all the fluid!
Glad this post came up because I didn't think about that earlier..........there is always something left undone.
Not sure I completely follow your question. If the trans has the opening for a speedo cable fitting, just get one and bolt it in. If the trans has a plug in the hole, knock it out and install the drive gear as I noted above. If there is no opening, you're SOL.
I doubt the front hub on the '46 has a hole in the spindle to accomodate the cable, and then, I don't have the cable assembly either. Going to have to think this one out some.
I'm in luck, there is a "knock-out" plug on the side of the tranny and I bought the housing and gears for the speedo, I just don't have the cash to get it fixed right now
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
![Stick Out Tongue](https://classicoldsmobile.com/forums/images/smilies/tongue.gif)
coconv
October 14th, 2012 01:32 PM
