Diff style Hurst shifters?
Just curious... in all the pics I have seen so far, the holes circled in red below do not have notches, but this one does. Were there variations? This be a 3138 shifter.
Yes,there are different styles.Those levers pictured,have smaller holes,and use a rubber bushing/gromet. The holes without the notches are larger,and they take the brass or steel bushings & thrust washers.
The rods will fit. either style. The shifter levers without the holes are larger holes,and they use a steel or brass bushing with the rod,whereas the shifter levers with the notches have a smaller hole,and the rod is a snug fit in that hole.The rubber grommets in that application do not act as a sleeve or bushing.They lock in place & are used to take up any side-to-side play in the connection.
70-72. Some people will drill-out the notched holes,so the bushing kits will work with them.I have found that the rods usually wear before the holes in the levers,so if you use new/reproduction rods,everything should be nice & crisp.
Looking at the kit ILT sells for example... theirs is for the 'round' holes?
http://cgi.ebay.com/ebaymotors/390168532339
Yes,I have that kit.The 3 brass bushing inserts will not fit your levers unless you drill the hole size larger.
I have also seen a steel type of bushing insert,with a thinner sleeve.I think those are a Hurst product.
Still don't understand the whole thing really. ILT only has that bushing set, and all the shifter/lever pics I have seen so far have round holes with no notches. Could this 3138 shifter be from some non-Olds 70-72 car?
Curious what the CSM and Assembly Manual for 1972 says. Have not looked yet.
Yes,the 72 convertible came with the M20. All 72 Cutlass/442's came with the M20,if they were a 4-spd.I'll take some pictures of that shifter,or another one,as I have more than one with the rubber grommets.
I sold a few set-ups in the last few months,since you inquired before,and some of them,I am doing the install swaps.I am just finishing the 71 442 convertible with the sienna interior,that I posted pictures of before,and with the pilot bearing adapter that I had made.It's up & running,and I drove it a few miles so far.I plan on doing some minore adjustmants & taking it out one more time.Then the owner's driving it back home on the highway.Troy Thornton wanted a complete set-up as well,so I need to check with him to see if his customer is still interested.I have a few more swaps scheduled,then we'll see what I have when I'm done.
This car isn't a frame-off resto,like some,but I only do things one way.Every piece that I install is restored,rebuilt,replated,etc.
