Diff style Hurst shifters?
Old Jul 10, 2011 | 08:52 PM
oldzy's Avatar
Just curious... in all the pics I have seen so far, the holes circled in red below do not have notches, but this one does. Were there variations? This be a 3138 shifter.
Old Jul 13, 2011 | 07:56 PM
oldzy's Avatar
Old Jul 20, 2011 | 04:34 AM
507OLDS's Avatar
Yes,there are different styles.Those levers pictured,have smaller holes,and use a rubber bushing/gromet. The holes without the notches are larger,and they take the brass or steel bushings & thrust washers.
Old Jul 20, 2011 | 08:19 AM
oldzy's Avatar
Curious... if a rubber grommet goes in the holes, do the notches serve any function? Also, are they correct for 1972? thx
Old Jul 20, 2011 | 08:23 AM
507OLDS's Avatar
The rubber gromets are notched to lock into the notches in the levers.
Old Jul 21, 2011 | 09:53 PM
oldzy's Avatar
So does that mean there are 'round' and 'notched' levers as well? I be boggled.
Old Jul 22, 2011 | 05:20 AM
507OLDS's Avatar
Yes,there are 2 different types of holes at the ends of the levers.Round or notched.
Old Jul 22, 2011 | 08:43 AM
oldzy's Avatar
So if I order some repros from Fusick, ILT or whatever... I may get the wrong rods?
Old Jul 22, 2011 | 09:43 AM
507OLDS's Avatar
The rods will fit. either style. The shifter levers without the holes are larger holes,and they use a steel or brass bushing with the rod,whereas the shifter levers with the notches have a smaller hole,and the rod is a snug fit in that hole.The rubber grommets in that application do not act as a sleeve or bushing.They lock in place & are used to take up any side-to-side play in the connection.
Old Jul 22, 2011 | 11:36 AM
oldzy's Avatar
k thanks. Is this shifter style (#3138 w/notches) correct for 72, or can be 70-72? Just curious.
Old Jul 22, 2011 | 08:38 PM
507OLDS's Avatar
70-72. Some people will drill-out the notched holes,so the bushing kits will work with them.I have found that the rods usually wear before the holes in the levers,so if you use new/reproduction rods,everything should be nice & crisp.
Old Jul 24, 2011 | 01:50 AM
oldzy's Avatar
Looking at the kit ILT sells for example... theirs is for the 'round' holes?
http://cgi.ebay.com/ebaymotors/390168532339
Old Jul 27, 2011 | 04:57 AM
507OLDS's Avatar
Yes,I have that kit.The 3 brass bushing inserts will not fit your levers unless you drill the hole size larger.
I have also seen a steel type of bushing insert,with a thinner sleeve.I think those are a Hurst product.
Old Jul 28, 2011 | 12:21 AM
oldzy's Avatar
Still don't understand the whole thing really. ILT only has that bushing set, and all the shifter/lever pics I have seen so far have round holes with no notches. Could this 3138 shifter be from some non-Olds 70-72 car?
Curious what the CSM and Assembly Manual for 1972 says. Have not looked yet.
Old Jul 28, 2011 | 05:30 AM
507OLDS's Avatar
I still have a complete,unmolested 4-spd set-up,from a 72 supreme convertible,and that shifter has the notched holes in the levers,with the rubber grommets.
Old Jul 28, 2011 | 05:38 AM
oldzy's Avatar
So there is the rubber grommet, then a washer/cotter pin or something on each one?
Did the 72 CS convert. come with a M20? Any pics?
Old Jul 28, 2011 | 05:45 AM
507OLDS's Avatar
Yes,the 72 convertible came with the M20. All 72 Cutlass/442's came with the M20,if they were a 4-spd.I'll take some pictures of that shifter,or another one,as I have more than one with the rubber grommets.
Old Jul 28, 2011 | 05:46 AM
oldzy's Avatar
Are you selling that unmolestered setup?
Old Jul 28, 2011 | 06:14 AM
507OLDS's Avatar
I sold a few set-ups in the last few months,since you inquired before,and some of them,I am doing the install swaps.I am just finishing the 71 442 convertible with the sienna interior,that I posted pictures of before,and with the pilot bearing adapter that I had made.It's up & running,and I drove it a few miles so far.I plan on doing some minore adjustmants & taking it out one more time.Then the owner's driving it back home on the highway.Troy Thornton wanted a complete set-up as well,so I need to check with him to see if his customer is still interested.I have a few more swaps scheduled,then we'll see what I have when I'm done.
This car isn't a frame-off resto,like some,but I only do things one way.Every piece that I install is restored,rebuilt,replated,etc.
oldzy
Dec 17, 2010 10:37 PM
jcl
Aug 5, 2010 06:51 PM
crash
Nov 18, 2009 05:14 PM
wmachine
Aug 9, 2009 07:05 AM
88hurstolds
Dec 11, 2008 11:28 AM
