Crankshaft bushing for auto to manual conversion
Old Aug 19, 2014 | 05:41 PM
Delmont 88 PA's Avatar
I'm thinking about converting my 67 Delmont 88 to a manual trans. One of the major issues is that the crank isn't drilled for the manual input shaft. Mondello sells a crankshaft bushing to make this conversion. Apparently the input shaft of the manual trans needs to be shortened.
Has anyone used one of these? Also, is there a good "one-stop" supplier for transmission, bell housing, flywheel, hydraulic clutch slave cylinder, etc.?
Thanks,
Chris
Old Aug 20, 2014 | 10:16 AM
d2_willys's Avatar
If you are taking the engine and transmission out as a unit, then why not pull the crankshaft and have a pilot bushing hole drilled and bushing installed. Most machine shops would do this for a small fee. I spent $10 years ago on a Rocket 371 that had DC hydro. I installed a Dual range hydro that had a pilot shaft. While you have the crank out, you can put a new rear main seal in and front seal.
Just a thought.
Old Aug 20, 2014 | 03:55 PM
Thanks! I'm trying to avoid taking the engine out of the car; however, this may be the only good option.
Old Aug 20, 2014 | 04:29 PM
Octania's Avatar
The conversion bushing can be done painlessly.
rather than shorten the trans shaft, get a 1/2" shank 5/8 drill bit and drill the crank a bit deeper. It is a clearance hole, need not be perfectly centered or round. WAY less work that the mitaswells you run into pulling the crank...
Old Sep 9, 2014 | 08:07 PM
Shradezz70S's Avatar
I am doing this right now. You need to make sure you press that bearing in as far as it will go. I put it in flush with the out side and the splines hit the bearing and the trans was about 5/8 of and inch out. I was not happy. Dick Miller sells the same bearing 20 bucks less than Mondello. I am installing a TKO 600 in my 1970 S
olds70supreme
Sep 1, 2014 12:05 AM
65442ragtop
May 21, 2014 10:31 AM
The Bug Man
Aug 7, 2013 10:34 AM
CS455
Dec 30, 2011 01:02 PM
Aceshigh
Jan 27, 2011 04:28 PM
