Clutch size
Old Feb 5, 2020 | 02:37 PM
77442's Avatar
Clutch size
Do all Oldsmobile Cutlasses with a manual transmission have the same size clutch?
I have a 77 442 with a 260/T-50 combo and plan to put a 455 in place of the 260. I've looked on line and see that 10.5 and 11' clutches are available but seem to interchange between the two.
Can somebody give me the scoop on which clutch goes to what?
Thanks.
Old Feb 5, 2020 | 03:50 PM
SBOs used 10.5", BBOs used 11". The flywheels should be drilled for both (well, they were so long as the BBO was being made). And yes, the W37 is the exception to this.
The question is irrelevant if you plan to put the T50 behind a 455, however. That trans won't make it to the end of the driveway.
Old Feb 6, 2020 | 08:38 AM
brownbomber77's Avatar
Yep, really gonna need a TKO600 for that as well as the mid shifter...and will have to cut a hole in the floor. I have a '77 and had to cut the floor for the TKO. it fits though....
Philthytoo
Oct 9, 2017 07:29 AM
David DeCan
16
Jun 4, 2017 06:32 AM
Cincinnati Rick
Aug 3, 2015 07:08 PM
bummerino
Apr 27, 2010 08:55 PM
mugzilla
Sep 7, 2009 05:57 PM
