Clutch fork issues
Clutch fork issues
So I began getting my Saginaw 4-speed ready because I had some spare time, when i started mocking where the bellhousing would go on to see if the clutch fork I had would fit. It snapped on but had clearance issues with the bellhousings fork hole.
The trans was off of a chev motor including its fork and housing and I am using the trans with my 350 olds so I got the shown BOP housing cheap to mate up.
My question is, if I buy a new fork, will it be different? The forks on summit say they fit olds AND chev, so shouldn't this one, or do I need to find another housing. any knowledge I can get will be appreciated.
Is there more than one hole in the BH for the ball stud to screw in to? As in, can it be moved up? I believe that all of the forks are generally like the one you have in the pic. If the ball stud cannot be moved, then you need a different BH, or relieve the bottom of the opening for clearance.
Thanks for your help
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
You have a G body bellhousing, it takes a special fork. It is sorta rare and worth more than the bellhousing you need. If you grind on it you will ruin the value. I would find the correct housing and sell that one for profit.
Russ
Russ
Hey thanks, I didn't even think about the applications, I don't like to cut up old things and was searching for a bellhousing. Would you happen to know what sort of value I am looking at, Canadian-wise, things just seem to have higher prices in Canada probably the Supply and demand factor, thanks for your help
What exactly is the difference? Because for a different fork to work it would need to have an off-centered clip for the pivot ball or be a strange S shape. The housing has an indent above the pivot ball where the pivot ball needs to be for my application, wouldn't what Russ said make sense? That it is just for a different model(s) and there were two locations for the pivot ball and this one is the wrong one? I wish it had a code so I could at least look it up
I was thinking in A body terms and what I said may not be true with the Omega. With the A body there is a certain shape fork that they all used with Olds engine. The Z bar changed some over the years but the fork did not at least from 64 to 72. I thought all the bell housings were basically the same so then the forks would be too....?? Could be wrong, have no Omega experience.
RandyS
March 11th, 2013 09:41 PM
