Does anyone know the part number for a 1968 442 bell housing (manual)? I searched CO but didn’t see an answer, so I hope this isn’t a repeat question.
Casting No. 9785581. This is the common BOP bellhousing used in the 1960s. Correct for 1964-1975 Oldsmobiles. It is drilled for both the GM manual trans pattern (Saginaw and Muncie) as well as the Ford trans pattern (as used on the Dearborn HD 3-spd trans). Starter notches on both sides to fit Buford as well as Olds and Pontiac blocks.
