Bell Housing Question
Old Aug 17, 2012 | 10:16 AM
Kevin W's Avatar
Does anyone know the part number for a 1968 442 bell housing (manual)? I searched CO but didn’t see an answer, so I hope this isn’t a repeat question.
Old Aug 17, 2012 | 11:15 AM
Casting No. 9785581. This is the common BOP bellhousing used in the 1960s. Correct for 1964-1975 Oldsmobiles. It is drilled for both the GM manual trans pattern (Saginaw and Muncie) as well as the Ford trans pattern (as used on the Dearborn HD 3-spd trans). Starter notches on both sides to fit Buford as well as Olds and Pontiac blocks.
http://www.4speedconversions.com/581.html
Old Aug 17, 2012 | 01:52 PM
jensenracing77's Avatar
do you need one? i have several
Old Aug 17, 2012 | 07:29 PM
Run to Rund's Avatar
"Casting No. 9785581"
The casting number is also the part number.
Old Aug 17, 2012 | 08:01 PM
Kevin W's Avatar
Thank you guys.
jensenracing77
Dec 20, 2022 12:37 PM
mono-plane
Oct 15, 2009 04:40 PM
silverriff
Nov 17, 2008 06:29 PM
dan2286
Jul 26, 2008 05:00 PM
ozoneblue
Aug 21, 2007 05:59 PM
