Auto to T5 Manual Swap Help Please
Old Oct 12, 2012 | 01:09 PM
Propaneking's Avatar
Someone who has done an auto to T5 swap willing to help with some question? 1972 Automatic 350 motor convertible.
Old Oct 13, 2012 | 11:23 AM
2blu442's Avatar
If nobody's replied to this yet send me a PM and I may be able to help.
John
Old Oct 21, 2012 | 09:13 PM
The_Jeremiah's Avatar
do yourself a favor, dont use a T-5, you will break it. you might be alright with a world class t-5, I wanted an overdrive trans, through a bunch of research I decided on the T-56 If you want to swap to a manual, you will need the pedal box, linkage, trans, crossmember, one of the problems with the oldsmobile engines is the crankshaft isnt drilled for a pilot bearing. I know theres a few people that have found easy solutions to this. someone will chime in
Old Jan 16, 2013 | 06:00 PM
1964f-85's Avatar
I have a WC T-5 out on a 86 Mustang GT in my F-85. I rebuilt it with stronger internals, but summit has an equal replacement for about $1200.00. I drilled my crank using a jig that we made to center a bit on the crank. The hard part is that you will need to machine an adaptor plate that moves the transmission back. The plate bolts to the BOP belhousing, and has the ford bolt pattern. Everything else is stock. Not easy! I would convert to a muncie first.
Old Mar 1, 2013 | 10:53 PM
65B01Delta's Avatar
I would like to see a picture of the jig you made. I have a crank that I need to drill...
Thanks,
Old Mar 2, 2013 | 07:06 PM
Pat McClelland's Avatar
If you machine a plate to move the tranny back you can put the pilot in a spool machined to center in the flywheel. Porche does this and I have used it to hook a t-56 to the 371 motor in my 57. My t-56 was an aftermarket version intended for Mustangs and came with a 1/2 inch steel plate on the trans which we drilled for my Offenhauser bell housing.
68cutS
Aug 16, 2015 06:17 PM
jon69olds
Nov 4, 2010 11:11 AM
DaGOONIE
Drivetrain/Differentials
Aug 29, 2008 12:25 AM
cruznn
Sep 24, 2007 07:09 AM
drtdobber
Feb 14, 2007 01:16 PM
