Adapters
Old Nov 25, 2008 | 11:11 PM
projectheaven's Avatar
Adapters
Is there a adapter thats sold that can mate a trans other than a "bop" to a 455 olds engine?
Old Nov 26, 2008 | 04:56 AM
citcapp's Avatar
Yes there are adapter plates for other GM transmissions they add about 1/2" to the length of the transmission
Old Nov 26, 2008 | 05:34 AM
Just to be clear, the adapters that are commonly sold allow the BOP and Chevy pattern transmissions to be interchanged. This lets you mate a 700R4 to an Olds, for example (though I'd still go with a built 200-4R). Note that the dowel pins and bottom two bolts are the same for these two bolt patterns.
Old Nov 26, 2008 | 06:05 AM
IF you go with a 200 4R it will have to be built to withstand the torque of a 455. Go to the Turbo Buick forum and get ahold of Brian Hofer. He is a 200 4R guru. The adapters are readily available on Summit. One company that makes them is TransDapt.
dnmfranco
Apr 14, 2014 10:20 AM
HP Hunter
Nov 11, 2011 05:26 AM
whosyourdaddy
Ninety-Eight
Apr 8, 2009 05:56 PM
cowboy76
Jan 23, 2009 08:33 AM
