accumulator cover leak
Old Jun 3, 2008 | 05:33 AM
bulldog's Avatar
My 71 Cutlass started to leak Trans Fluid from the accumulator cover.
Can anyone guide me thru the repair. I need to know what parts are required for the repair as well as what tools will be needed.And the difficulty of said repair. Thanks
Old Sep 17, 2008 | 05:15 PM
d2_willys's Avatar
Pretty easy if there is enough room down there. My 78 Buick th350 started leaking out of the same cover, and it turns out to be a simple O-ring. From what I remember you simply use a drift pin thru the bottom of the accumulator boss and get the round retaining clip out. The cover will then pop out and the O-ring will be there. Replace it and reinstall cover and retaining clip.
63super88
Apr 6, 2014 06:51 AM
tobywoodard
Nov 16, 2013 06:46 AM
Gary's 2 442-S
Sep 24, 2012 10:56 AM
DeltaDevil88
Jun 29, 2012 01:12 AM
nonhog
May 2, 2010 02:06 AM
