75 Turbo 400 in 65 Jetstar 1
Old Jul 29, 2009 | 11:42 AM
nickd's Avatar
I made an engine and trans swap recently and noticed that the trans shifts way to early (3000 RPM) at full throttle. What am I missing here were the 75 's electric shift? Is there any way I can fix this ? The only thing I don't have plugged in the trans is the speedo cable as mine runs off the front tire. Thanks
Old Jul 29, 2009 | 11:54 AM
wmachine's Avatar
Trying to remember member
Not that it has anything to do with your question, but I'd like to see pics of your JS1.
Old Jul 29, 2009 | 01:13 PM
If by "electronic shift" you mean computer controlled, no. That did not start until the 1990s and no TH400s were ever computer controlled. Likely places to look are the vacuum modulator and/or governor.
Old Jul 29, 2009 | 04:33 PM
nickd's Avatar
65' Jetstar 1 never restored painted once.An updated pic with it cleaned upic with it cleaned up
Old Jul 30, 2009 | 07:57 AM
citcapp's Avatar
Check for a vacum leak on the rubber portions of the line to the modulator. I had a bad fitting rubber hose at the modulator on mine. Once I fixed the vaccum leak it shifted just fine,
Nice pictures good looking car
Old Jul 30, 2009 | 11:56 AM
svnt442's Avatar
You can hook up a kickdown wire with a micro switch (like used for a nitrous system) to get the kickdown working. Just hook to a 12V source.
As far as the way early shifts check the modulater and the governor.
Old Jul 30, 2009 | 02:47 PM
d2_willys's Avatar
Hey that Jetstar looks like the car that Kevin drove in the WONDER YEARS SHOW. His was blue and had the chinese restaurant number decal on the door. Man I am really showing off my age now.
Nice car, what does it have for a mill, 330?
Old Jul 30, 2009 | 03:10 PM
nickd's Avatar
Original came with a 425 but now has a 75 455
Old Jul 30, 2009 | 06:38 PM
wmachine's Avatar
Kevin drove a '65 Cutlass, not a Jetstar 1. All Jetstar 1s came with the 370 hp 425. It was the only engine available on that model.
Old Jul 30, 2009 | 08:23 PM
Danny Wiseley's Avatar
I think the '65 came with a switch-pitch TH400 having two wires going to the transmission. The '75 should only have one connector--for the kickdown/shift speed control. Make sure the correct wire is on that terminal and gets voltage at WOT.
Good luck.
DW
Old Jul 31, 2009 | 06:17 AM
d2_willys's Avatar
Yep u r correct. Kevin couldn't (or his grandpa, where he got it from) afford the Jetstar I.
Switch pitch is better than the 75 TH400 IMO.
Old Jul 31, 2009 | 07:09 AM
wmachine's Avatar
I believe so, too. Mostly due to the converter.
I prefer the 4-speed of course....
Old Jul 31, 2009 | 06:58 PM
nickd's Avatar
I don't beleive it is a switch pitch I think the Starfires got them. It is a factory 3 speed auto. Could it be shifting so early because it is a quart overfilled? Or maybe the screen?
Old Jul 31, 2009 | 07:04 PM
wmachine's Avatar
Starfire and Jetstar 1 drive trains were identical.
Old Jul 31, 2009 | 07:23 PM
nickd's Avatar
The original trans was leaking pretty bad and would not shift @ full throttle unless u let off and hit it again real quick but regular driving it would shift great I actually liked it because I could get a nice rip out of the tires hitting secong very easily with it. Made a couple old R/T's back down I will make sure I have the right wire hooked up. Thanks
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
