72 CS Transmission Issue
Old Nov 1, 2013 | 05:04 PM
MrTorresJr's Avatar
I have driven my 72 CS a few times and never encountered this issue that I did today. I positioned it in 'DRIVE' and upon accelerating it sounded as if the RPMS were increasing yet the speed was not. I flushed the tranny, replaced the gasket & filter about 1 month ago, thoughts? I tried shifting through the gears and still encountered the same issue.
Old Nov 1, 2013 | 06:40 PM
Are you sure the tranny has enough fluid? If it worked fine before the flush chances are you just need to top it up?
Old Nov 1, 2013 | 07:56 PM
Please note, I moved your post to the correct category.
I would check the hose to the modulator and/ or the modulator itself. Item #2 would be to check the detent cable between the gas pedal and the transmission to see if the trans is hung up in passing gear.
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
Outlaw88
Nov 3, 2013 10:41 AM
MrCoolbreeze55
Jun 19, 2013 08:34 PM
boylost
Aurora
Aug 29, 2006 06:46 AM
