71 350 to 4l60
You may have issues with getting the electronic trans to shift without a computer. The 4L60 (not e) is effectively the same trans, will do the same job, and uses a cable for kickdown and shifting.
The 4L60 (sans "E") is just a 700R4 with a different name. You'll have the same durability issues with either. Personally I prefer a built 200-4R, especially since there's no need to mess with crossmember location or driveshaft length. In any case, be wary of the adapter plates. Some only pick up four of the six bolts in the BOP pattern. Get one that uses all of them.
