67 power glide
Old Nov 4, 2017 | 05:35 AM
brianbeez67's Avatar
67 power glide
Hey guys, got a question on swapping transmissions. I currently have a 2 speed power glide "console shift" in my 67 cutlass supreme. I will be swapping it with a 2 speed from a steering column shift (also 67 cutlass).
Are there any pitfalls or should this be a clean 1 for 1 swap ?
thanks as always Brian
Old Nov 4, 2017 | 05:42 AM
#1, if its the stock trans you don't have a power glide, its an ST300 with a switch pitch torque converter. If your swapping with another 67 ST300 then its a clean swap.
Old Nov 4, 2017 | 07:06 AM
As Eric pointed out, Olds never installed a Powerglide. Other than having two speeds, the ST300 (also called Jetaway in the factory literature) has exactly nothing in common with the PG.
The trans neither knows nor cares if the shifter is on the column or the floor. You will have to swap the correct shift lever onto the trans manual shift shaft, but that's one nut. Other than that, there is no difference.
Old Nov 4, 2017 | 11:59 AM
thanks for the response, thought the terms were interchangeable. hope to pull the engine and trans together soon.
olds67
Jan 27, 2014 02:43 PM
Nor Cal Andy
Mar 29, 2012 08:20 PM
1966 f85
Jul 7, 2010 05:49 PM
KZ442
Apr 10, 2009 03:16 AM
1FSTLS1
May 30, 2008 07:42 AM
