65 olds 442 clutch equalizer
Old June 21st, 2016, 02:53 PM
dmw1948's Avatar
Any ideas as to how to locate where to weld the clutch equalizer... 65 was not a bolt on year... Engine and trans are out of the car right now
dmw1948 is offline
Old June 22nd, 2016, 07:14 AM
dmw1948's Avatar
Anyone got a source for a 65 factory template as to where to locate the clutch equalizer on the frame?
dmw1948 is offline
Old June 22nd, 2016, 02:42 PM
I merged your identical threads. It is neither necessary nor in your best interest to post the same question in multiple threads. You'll get a better answer if you keep all responses in one thread, so incorrect info can be caught and corrected.
The diagram is in the Assembly Manual, in Group 7 - Transmission. There is a Frame Gauge Hole in the straight part of the frame under the firewall. The centerline of the pivot on the tab should be 7.22" up from the center of the gauge hole and 9.28" forward.
joe_padavano is offline
Old June 29th, 2016, 07:52 AM
dmw1948's Avatar
65 442 manual transmission
Thanks... I'll share your answers with my mechanic.... You don't have any pics of the parts as assembled would you? I see you have a 66... should be the same, No?
dmw1948 is offline
Old June 30th, 2016, 12:21 PM
dmw1948's Avatar
ooops
This is a WTF kinda answer... it appears that our assembly manual was missing several pages...got the right pages and now and understand...just need to make the template and away we go...Thanks again
dmw1948 is offline
BeenThere
December 23rd, 2017 11:36 AM
Suede53
June 24th, 2016 06:35 AM
BeenThere
January 7th, 2013 12:09 PM
dancutlass
17
May 17th, 2012 09:47 AM
thekustom
February 12th, 2012 02:47 PM
Quick Reply: 65 olds 442 clutch equalizer
