65 F-85 floor shifter. What year will work
Old May 9, 2009 | 02:17 AM
jessejames's Avatar
Converting from a column shifter to a floor shifter and my car is a 2 speed jetaway. (65 f-85) Will a 2 speed shifter from a 68 cutlass work in mine?
Old May 9, 2009 | 04:25 AM
442scotty's Avatar
Dont see why not...64-66 used the same shifter...linkage type...68 is cable type so you need all the tranny brackets as well from the 68
Old May 9, 2009 | 07:18 AM
2blu442's Avatar
You could probably do some fabrication and make it work. The factory style shifter and console was the same up until 1966, then they changed to a style that mounts to the floorboard differently. If you were going to install a 1965 style console you'll probably need to stay with the early shifter design. John
69CutlassAlex
Feb 9, 2012 05:26 AM
boondocker
Non-Olds Engines
Dec 10, 2011 06:06 AM
1983oldsmobiledelta
Oct 7, 2010 02:55 PM
jensenracing77
Feb 10, 2010 04:50 PM
olds4life
Feb 27, 2009 08:54 PM
