55 slant pan connection to carb
Old Apr 27, 2023 | 06:21 PM
Kbs's Avatar
Kbs
Hi
i have a 59 371 with a 55 slant pan automatic. There is a linkage between the carb and the trans. I am not sure what this is but I am guessing this is the kick down. Is that necessary for this transmission? I dont really need the kick down function and would like to remove it so I can go to the standard rochester 2 barrel butterfly linkage. Thanks for any help
Old Apr 27, 2023 | 08:42 PM
d2_willys's Avatar
Originally Posted by Kbs
Hi
You will need the linkage as it is necessary. It is not just a kick down rod but a TV rod. It controls internal oil pressure much like a vacuum modulator does.
Old Apr 27, 2023 | 08:54 PM
Kbs's Avatar
Kbs
Thank you for the help. I will have to figure out another way to work with the butterfly linkage. The one i have has been customized. The rod was drilled out and tapped to hold the custom linkage. The tap leaves very little wall thickness left so the bolt doesnt hold the plate tight.
again thanks for the help
Old Apr 28, 2023 | 07:22 PM
Kbs's Avatar
Kbs
Hi
Do you know where i can see the “factory” connector for this transmission to the rochester 2 barrel? The standard rochester doesnt have the trans connection and i am wondering what they looked like when they rolled out of factory. Thanks
Old Apr 29, 2023 | 06:02 PM
Charlie Jones's Avatar
Phantom Phixer
Hi
This is a 1952 illustration, but '55 is much the same.
File Type: pdf
Old Apr 29, 2023 | 06:07 PM
Kbs's Avatar
Kbs
Charlie
thank you very much “! This helps a lot. I now understand what my father was doing when he did the customization to the throttle linkage.
Tedd Thompson
Oct 6, 2025 06:11 AM
rktrde303
Feb 15, 2023 01:29 PM
setzman
Aug 9, 2018 05:49 AM
theold52
Dec 7, 2017 07:00 PM
scharpp
Mar 4, 2015 10:26 AM
