400 trany
Old Oct 19, 2005 | 06:04 PM
Freddy57's Avatar
Post
Need to know the best way to find a 400 trany for a 1977 oldsmobile cutlass
Old Oct 25, 2005 | 09:18 AM
jdorour's Avatar
Post
You can find a THM400 in any junk yard.
A THM400 out of a 1968 and later Buick, Pontiac or Olds will fit. You will need to have the driveshaft short and you will need to change the front yoke on the drive shaft. The 400 trans was used on the big block cars until 1976 and the 375B was used until 1980. Most of the time all you will need to do is move the crossmember aft to the holes that are already drilled in the frame.
Railguy
Nov 3, 2012 08:08 PM
Stevec
Jun 27, 2012 05:12 PM
doc93
May 19, 2010 05:15 AM
74 Omega
Jul 15, 2008 05:06 PM
luckyford65
Feb 4, 2007 11:17 AM
