Trany problem
Old Oct 22, 2012 | 04:46 PM
Railguy's Avatar
Trany problem
My son's trans is like slipping between shifts its worse out of overdrive than in.once its in gear it's fine.I'm sure it's something simple I hope.It's a 93 full size Blazer.
railguy
Old Oct 22, 2012 | 04:57 PM
nofiveo's Avatar
Check the fluid level first.. if the level is good, drop the pan and change the fluid and filter. look for chunks while you have the pan down. If theres excessive pieces/ filings, it'll need to come out.
Old Oct 22, 2012 | 05:08 PM
Railguy's Avatar
Fluid level is good just put the trany in it should be good.I was thinking it was the modulator?
railguy
Old Oct 22, 2012 | 05:15 PM
compedgemarine's Avatar
what trans is it? if it is a 700r4 is the tv cable adjusted correctly? if not it may not be bringing the pressure up properly.
Old Oct 22, 2012 | 06:18 PM
Railguy's Avatar
It's a 700 r don't know about the 4.Whats the tv cable. It just started doing this.It dosen't do it once it shifted you can stomp on it all you want and it willn't slip.The engine is real strong lots of power.
railguy
Old Oct 22, 2012 | 07:05 PM
I am no expert on transmissions but know enough to get in trouble. the 4 just means it has 4 speeds. the tv cable looks like the kickdown cable on a th350 but it controls pressures. it hooks up to the carb and generally should be pulled all the way out at WOT. if it is not hooked up or is out of wack it will not have the proper pressures to shift correctly. hopefully some one with better knowledge of these trans will chime in.
Old Oct 23, 2012 | 12:40 PM
1970-W30's Avatar
Throttle valve cable adjustment is critical......just Google "throttle valve cable adjustment" and you will find lots of help... try this first before pulling the trans.
Old Oct 23, 2012 | 04:21 PM
Railguy's Avatar
I don't think it has a tv cable.We just changed the trans and I'm pretty sure I don't re member disconnecting and reconnecting one,but I'll check to be sure.Is there any electronic eqwivalent to one?
railguy
Old Oct 23, 2012 | 05:35 PM
not in a 700r, after that trans was a 4L60 and then a 4L60E (e for electronic). the tv cable goes in on the side similar to a kick down on a TH350.
Old Oct 23, 2012 | 09:51 PM
1970-W30's Avatar
If it is a 700r4 transmission, it DOES have a tv cable and if you don't have it hooked up and adjusted properly, chances are you will ruin the transmission...... Google is your friend, lot's of info available, trans identification by oil pan shape, TV cable adjustments, companies that sell the cable etc.
just my 2 cents worth.......
Old Oct 24, 2012 | 10:42 AM
Railguy's Avatar
If it's a 4L60E does it have a TV cable?I'm pretty sure it's electronic dose the 700 R4 come in electronic version?
railguy
Old Oct 24, 2012 | 04:10 PM
the 4L60E does not have a tv cable but has to have a computer to shift it. I dont recall ever seeing a 700R4 that did not have a tv cable.
Old Oct 24, 2012 | 04:40 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That is a two year transmission, 93-94 are indentical. I picked a 93 4L60E for 94 Olds 350 powered Z71. $500 for a near fresh rebuilt trans was a steal. The shifts are controlled electronically, no TV cable. Make sure the main connector is in right. Not good, might be pulling time.
Old Oct 24, 2012 | 06:35 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
How many miles on the trans? Has it had regular fluid and filter service every 25-30K? If not it’s most likely time for a rebuild. Non High Perf 700s are noted to smoke the 3-4 clutch pack and the lock up frictions the converter (OD chatter). You need to have the pressures checked at the service port on the driver’s side. The pressures are the best way to check trans health. If it does indeed need a rebuild make sure who ever performs it will put all the applicable upgrades into it. Step up to the higher quality frictions and band. Also put the improved servo piston & spring assembly in as well as a shift improver kit (shift kit). There should be a couple of spring and valve upgrades in the valve body. A high quality kit will contain some of this but not all. A competent tranny shop will have the rest. If you don’t have a cooler have it properly installed (you use the radiator as well as the cooler in series).
Also consider a crate TCI trans from Jegs with all the goodies already installed and ready to go with a warrantee. Get the TCI fluid too.
Old Oct 25, 2012 | 09:36 AM
Railguy's Avatar
I just dropped the pan fluid looked good it was a quart low.There was a ball bearing in the pan nothing else,very little crud or whatever just the ball bearing.Could this be from a check valve?I took it for a drive still doing the same thing.
I just installed this trans a few months ago the other one had a broken case.I had a reparable shop change everthing over to another case he said every thing was good inside except a shaft that he replaced.
I'm pretty sure it's a 4L60E.
railguy
Old Oct 25, 2012 | 12:10 PM
If you’ve found a check ball you definitely have a problem. Not sure how a captive check ball could escape from its home. A valve roll pin stop may have come lose and allowed a valve to shift beyond its captive stop allowing the check ball to be spit out but I'd think you’d see the roll pin, spring and the valve too? This would indicate an unchecked worm passage circuit. I've never seen or heard of this but I haven’t seen as many transmissions as a rebuild shop. Google it. Get it diagnosed asap. You run the risk of burning it up if not already toast. A pressure check will zero in on the problem. You might get lucky and the valve body may be the only thing needing service? Either way don’t drive it until the probs fixed. Let us know what was found.
Old Nov 2, 2012 | 06:37 PM
Railguy's Avatar
Found some info on another site.
http://autoforums.carjunky.com/Autom...n_pan_P128997/
railguy
Old Nov 3, 2012 | 08:08 PM
Yep there you go. Get it serviced before further damage. Thanks for the informative link.
Stevec
Jun 27, 2012 05:12 PM
doc93
May 19, 2010 05:15 AM
74 Omega
Jul 15, 2008 05:06 PM
luckyford65
Feb 4, 2007 11:17 AM
Freddy57
Oct 25, 2005 09:18 AM
