4 Speed Swap
4 Speed Swap
Hey Guys,
I was wondering if any of you could point me into the right direction on what it would take (documentation, parts, etc) to do a swap on my tranny. I wanna take out the th350 that's in it and put in a 4 speed manual transmission. The TH-350 already isn't the original transmission so i'm not worried about swapping it out.
I understand that this will take a lot of work and will require me to do some modifications, but Any help/info would be greatly appreciated.
--Just some info. My car is a 68 442, and already has a Hurst floor shifter. Motor is the original 400BB and the current transmission is a TH-350.
Thanks guys!
Thanks guys!
When researching doing a auto -> 4-speed swap, other than the pedals, linkage, and whatnot, I also read that the crank has to have a hole in it for the pilot bearing. Unless the car was a 4-speed to start with, I am not sure how you would have that milled out with the block in the car, but I could be wrong.
Big Mikey
March 27th, 2013 06:51 AM
'69CutlassVert'
August 25th, 2011 07:19 AM
Winnipeg Cutlass
April 17th, 2006 03:15 PM
