350 turbo stall converter question???
Old Sep 7, 2009 | 10:31 PM
455Gbody's Avatar
I have a Olds 350 turbo trans and have found good deals on quite a few chevy stall converters... so my question is will one of these chevy stall converters work with my Olds tranny? is it compatible?
Old Sep 8, 2009 | 09:43 AM
All TH350 and TH400 converters interchange (except for the switch pitch TH400s from 65-67).
Old Sep 8, 2009 | 10:50 AM
This is a good question. Summit sells numerous torque converters under their "house brand." Unfortunately, they are only listed under Chevy on their website. Check it out:
http://www.summitracing.com/search/D...t/?Ns=Rank|Asc
Old Sep 8, 2009 | 11:18 AM
captjim's Avatar
The only issue I have ever come across is that an "Olds" converter has a threaded boss where the "Chevy" converter requires a nut and bolt. You may have to clearance the flywheel weight a tad or use a spacer, but no biggie either way.
ELECMAN
Jun 7, 2014 05:05 PM
quentinnw2
Oct 13, 2013 07:19 PM
KeithsCustCutlass
Oct 12, 2011 10:47 AM
stlregal
Nov 17, 2010 04:54 PM
455Gbody
Sep 1, 2009 02:46 AM
