350 Transmission
350 Transmission
Continued from the New join thread...I took some pics of the Tranny today. I believe it is leaking from the rod that changes the gears and traveling around to rear of the pan then leaking off from there. My driveway is slightly sloped downward which would explain the build up in the back of the pan. Its not leaking terribly bad and the fluid level was still good. i think im gonna pull it out tomorrow after I find tranny jack or try to modify mine with a couple pieces of wood or something. Let me know what you think.
esisson
May 22, 2008 07:47 PM
