350/th350 swap for 455/th400 help?
I have a 70 cutlass with a 350 that I'm putting a 455 along with a 400 short tail trans. Also going in is a 12 bolt rear end from what seems to be a 69-70 gto with 4:56, but i wiuld want to change gears to 3:73.
Would any one be able to tell me what parts I would need and what changes to make if any?
Last edited by 70cutman; May 21st, 2011 at 06:00 PM. Reason: found out the trans is a short tail
You'll need a different driveline length, and the TH400 has an electrical kickdown switch mounted to the gas pedal vs the TH350 with a mechanical cable. You'll likely have to change the speedometer drive gear in the transmission once you get the rear end gears and tire size decided. That's what comes to mind for me, others will have to add what I've missed. Physically everything bolts up and should be a straightforward swap. John
Also, where can I find the switch and assembly for the gas pedal?
i don't know what that rear end is but a th400 with an O type (12 bolt cover) needs a 54 1/2 to 55 inch drive shaft. not sure your rear end will be the same length from a Pontiac. if you don't have one you will need a yolk for a th400.
The Chevy 12 bolt uses a different driveshaft length than the Type O axle. Yes, even the short tail TH400 needs a different driveshaft.
Since you have to relocate the trans crossmember for the TH400, you will need to change the front and intermediate e-brake cables.
And DO NOT buy "455" motor mounts unless you change the frame mounts. If you keep the 350 frame mounts then use the matching 350 motor mounts.
If they are both 8.875" ring gear axles with twelve bolts holding the ring gear to the carrier, then yes. GM made a number of different axle housings with twelve bolts holding the cover. Contrary to popular belief, the "twelve bolt" designation really refers to the number of bolts holding the ring gear.
halfmoontrail
January 7th, 2013 05:54 AM
