2speed wont shift out of the blue
Old Jul 21, 2009 | 09:09 PM
65az's Avatar
ok... Trans worked fine yesterday.. now I have Reverse and 1st, but no second... any thoughts??
Old Jul 21, 2009 | 11:15 PM
88 coupe's Avatar
Junior Member
Vacuum modulator.
Norm
Old Jul 22, 2009 | 05:58 AM
Norm's correct, however it may be the vacuum modulator or simply the vacuum hose that connects to it. Verify that the hose is still connected and is not cracked. Also verify that it did not come off at the engine end. If the hose is good, replace the modulator.
Old Jul 22, 2009 | 09:29 AM
rocketraider's Avatar
Oldsdruid
If the car has electric kickdown (65 Jetaway should), make sure the kickdown switch isn't stuck in downshift position.
I had a 64 Tempest years ago that would stick in downshift 3 or 4 times a week. It would do it when you set the automatic choke on a cold start, as the switch was on the throttle linkage.
Old Aug 16, 2009 | 07:51 PM
65az's Avatar
Update! Ok.. finally had time to work on this... shifter is working properly. Checked the vacuum lines and the trans is getting vacuum to the modulator.. I am not sure how to check the kick down cable area... Any suggestions on where to get a new modulator for this Jetaway?
Old Aug 16, 2009 | 08:51 PM
Hairy Olds's Avatar
Shoveling Snow
On my 67 442 the Governor shaft was stuck. I used brake cleaner to free it up. Just be careful not to break the gear on the end. It's worth a look.
Paul
Old Aug 17, 2009 | 08:06 AM
65az's Avatar
Governor shaft? Where is this located at? As you can see.. I know nothing about transmissions...
Old Aug 18, 2009 | 11:43 AM
d2_willys's Avatar
Kickdown cable leads to transmission. Simply disconnect and see if it shifts. If it does then switch or wiring is getting 12V to it all the time and looking like a forced downshift..
Governor is located at the side of the transmission. Inside a roundish looking cover near back of transmission. Should be able to take govena (like the English put it) cover off and inspect to see if weights are stuck inward. Outward would make the trans shift very early at light throttle.
cut123
Sep 1, 2012 09:40 PM
wannaride
Nov 18, 2010 03:53 PM
Batmobile66
Jun 18, 2010 01:27 PM
troys2222
May 24, 2007 10:18 AM
mshavandy
Dec 19, 2006 08:05 AM
