200R4 Speedometer gear swap
Hi all.
Got my Delta back and just cleaning up some issues.
I know I have to drop the pan and drop the governor plate to get the speedometer gear on the governor.
I've never opened a trans before and the trans is going to be in the car for this. Everything looks pretty easy (famous last words, I know) but what about the pan gasket? Fel-Pro has a rubber gasket. Do I need RTV with that? any tips or tricks to install this since I'll be working under the car? How much fluid will I lose?
The other gear, I've done before
http://m.homedepot.com/p/Plasgad-Black-Large-Concrete-Mixing-Tub-887102C/205451585?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-AllProducts%7c&gclid=i&gclsrc=aw.ds
I use one of these to catch Trans fluid when pulling the pan. It is pretty cheap and big enough to catch most of it. I use a fiber gasket. Make sure your pan rail is flat and the trans case is wiped down and doesn't have debris on it. . You might want to pick up a governor cover gasket
The kit I got has a filter too. It's a "Pro-King" set. It's all made in China which I do not like
It's a rubber gasket. Do I need RTV? I was going to use a little bit, just to act like glue to hold the gasket in place while I bring the pan back up
Okay, I'll look into that.
Using thread is a neat trick. However, doesn't the gasket usually have holes just small enough to hold a few bolts in place (without them dropping out) as you raise the pan into place and start 2 or more of those bolts?
Personally, I'm going to invest in a pan with a drain plug for my next filter replacement. I have a large drain pan, but it still can make quite a mess unless you are VERY careful when releasing the last bolts and keeping the pan (heavy with fluid nearly to the top lip) balanced while lowering it.
GHOSTOWLGRID
June 20th, 2016 07:17 PM
cutsupreme72
May 3rd, 2016 08:32 PM
odddoylerules
24
January 22nd, 2014 06:35 AM
