200r4 in a 64 f85 any help
i was thinking of putting a 200r4 in my 64 f85 wagon, 330 2speed .. i am not sure about a few things like the flywheel and length differences.. has anyone already done one and could give me any tips...thanks..R.C.
Naturally you'll not be able to access all four gears manually with your stock column shifter and there is no easy way to convert your stock column shift quadrant. You'll need to adapt a throttle valve cable to the carb. You'll need to come up with some sort of converter lockup system (toggle switch, home brew, or aftermarket kit). Be sure to add an aftermarket trans cooler, as the 200-4R is very sensitive to heat.
thanks joe for the information.. i was mainly concerned with the 64 model flexplate having the right pattern for the t/c, and the overall length,.. and you answered that.. looks to be a easy swap compared to most . i guess for the lock-up control i would just wire it up to the 3-4 switch on the v/b. i guess they have that like on a early700r4. and make a throttle linkage for the t/v cable. i have several font yokes in case the spline count and size are different on the later trans. now all i need to do is convince my daughter that i need to dump the original trans ha ha ha ha
https://classicoldsmobile.com/forums...5-cutlass.html
Here is a link I hope to when I installed a 2004R in my 65.
thanks jag.. i can see already this swap will be breeze.. i have done a little custom work before.. check out my 6.2 turbo diesel into a 46 caddy swap.. now that had a few interesting fabricating issues..
http://s202.photobucket.com/user/rcp...****%20project
or my 46 camper build..
http://s202.photobucket.com/user/rcp...y%20for%20road
i like a challenge but this car my daughter is supposed to be building.. thats why i was looking for easy answers..
I should add one more thing on the 200-4R swap. Due to the relocated crossmember, you'll need to change the forward and intermediate e-brake cables. Use the ones for a 1967 442 with the TH400. These are available at RockAuto.
You never did mention if this is a flattop wagon or a VC. The flattop has the same 115" wheelbase as the 442, so the cables will be the same. The VC has a 120" wheelbase, so the intermediate cable is different.
hi joe..the wagon i am working on right now is a flattop.. wish it was a vista cruiser .. i bought this car because it was identical to one i owned back in 71.. i am restoring it for my daughter she wants it because it is just like the first car she ever rode in..
I'll give my standard response here. GM doesn't use different parts unless there's a really good reason. The cables need to work under the full range of manufacturing tolerances, brake wear, etc. You might be able to cobble something up, but why? The cables are relatively inexpensive and probably need replacement anyway.
thanks for the idea jag.. i think i already seen that maybe in a post by you somewhere else..
so true joe..a few bucks spent now can make a big difference in the long run when working with these old cars..
Because we aren't all made of money like you must be. What I did worked better than the stock set up and it cost about $1.50 for a 2 foot of 1/4" rolled steel, only a totally **** Olds guy would ever be able to tell the difference. Thanks for the insult!
When I installed the TH400 in my car year (and years!) ago I was able to use th factory TH350 parking brake cables with a extra set of the cable guides. I used the guides to take up the extra couple inches of cable slack. It was a free modification, I saved $1.50!
Ideally, the proper cables should be installed. Unless the car had a manual trans chances are the parking brake probably was used very little. The cables are probably rusted and wouldn't release the brakes. If replacement was needed obviously replace them with the correct parts.
The correct front cable is $24 at RockAuto. The intermediate is $11. Frankly, if you can't afford $35 after spending $1700 on a properly built 200-4R, you're cutting corners in the wrong place. I'm all for making things work, but I also recognize that the factory engineers developed the different length cables for a reason. These have been tested under a wide variety of operating conditions and brake wear conditions, which I doubt you did with your home-brewed solution. Cobbling something up may work fine 99% of the time, but what happens when you absolutely need it because your hydraulic brakes blew a line?
i got my 200r4 .. i hope it is a good one.. come from a low mileage mid 80's olds i think he said it was a 442.. but anyway i am hoping to just put it in with just a filter and seals change.. i have a picture of the tag i think it is the one i was told to look for..
i also picked up a engine looks to be a good one.. and it matches the car since it is a 64 330
link.. http://s202.photobucket.com/user/rcp...20olds%20wagon
well i am moving along on my daughter's 64 f85 wagon build.. i have good kz-f trans a rebuilt 330 4bbl. engine and a new 1406 eldelbrock carb, and spacer.. now i need to get a TV cable for it. i would usually build something myself but may be faster and cheaper in the long run to buy one already calibrated for my application. i was reading a post somewhere about a kit that had the brackets, throttle leaver and cable together in one kit but somehow lost the link. do any of ya'll have experience with those kits and if so which one would be best for my project.
i was also thinking that since i am not going to use the original jet away trans that came with my new engine.. what would a rebuilt jetaway trans with the 4jet carb and wiring be worth? it looks great and the fluid in it is extremely clean and red.. i could sure use the extra cah for the project
costpenn
September 20th, 2014 06:21 AM
1k442
August 23rd, 2012 12:15 PM
CutlassLegend
August 15th, 2011 06:18 AM
dhartley72
March 24th, 2011 05:38 AM
