200 R4 vs 4T80E
200 R4 vs 4T80E
Which would be a better solution for a 1970 Olds 442 with a 455, a 200 R4 or a 4T80E?
I am looking to go with an overdrive transmission, my turbo 400 needs a rebuild and freally want an overdrive to cruise on the highway.
Any specific suggestions on what to look for or model years transmissions to avoid or target.
Thanks in advance for the help.
Consider a beefed 200-4R. A properly built unit will cost about $1000 less than a 4L80E with controller, adapter, custom driveshaft, and custom e-brake cables (also about that much less than a Gear Vendors installation) and bolts right into your car. You will need a longer TH350 driveshaft, but the crossmember stays in the same place as for the TH400, so there's no need to change the e-brake cables.
4L80e is an indestructible beast.
Joe's spot on tho.....tunnel mods absolutely necessary.
I'm looking at these 2004R's for now because I can't get my T-56 in without
spending $1000 on parts I'm going to toss later anyways.
http://cgi.ebay.com/ebaymotors/2004R...Q5fAccessories
J-(Chicago)
Drivetrain/Differentials
December 11th, 2007 07:08 PM
