200-r4 swap
Old Feb 10, 2020 | 05:14 PM
meoff's Avatar
200-r4 swap
Been doing some research and most research is with someone changing out a TH 350 where the driveshaft does not have to be altered! If I do this conversion on the Cutlass is the driveshaft yoke compatible as I have a 400? And do I have to change the length? Any replies are greatly appreciated!
Old Feb 10, 2020 | 05:37 PM
svnt442's Avatar
You would need a new driveshaft and yoke. On the plus side (I'm assuming the 1970 in your avatar) you won't need new parking brake cables as the 200-4R uses the 400 mount location.
Gianni71Cutlass
Jun 13, 2016 07:46 PM
paul879
Aug 11, 2015 04:42 PM
josh stowe
Oct 21, 2013 08:33 AM
drec02
May 17, 2010 07:16 AM
grimlock
Jan 23, 2007 09:24 PM
