200-4r quadrajet linkage
help i need a picture of the stock tv cable arm that was on a sbo quadrajet with a the 200-4r maybe off a 307 .
i have two junk carbs that have a tv cable arm 1980 and a 83 carb the 83 has and electric idle(?) connection and the arm has the letter A on it both arms look the same . from info i've found the attachment point is 1.1" from c/l of throttle plate which looks close to what i have but others have said they used a turbo 350 set up, as it is close other posts say close is not good enough for correct cable travel so i'm not sure what i have a picture would sure help if anyone has a pic. of either type for comparison that would work
have the rebuilt upgraded 200, new converter , 350 yoke on the floor just would like the tv cable problem solved before i start. the builder said trial and error to set the tv cable but should i get the test gauge to set pressure/cable before i ever test drive from what i've read this setting is critical to the life of the trans which is why i want the correct linkage .
thanks, mike
thanks, mike
no response ? just to close this out if anyone is reading. i could not find a bolt on kit for the stock 72 t 400 carb. the arms off my later turbo350 carb have to be grafted on and then bowtie has a bolt on kit 129.00 plus 10 for a cable bracket . likely other ways to do it but i liked the idea of the bowtie bracket that has a cam the cable rolls up on to give the proper amount of travel .
sanemb
May 28th, 2008 05:43 PM
