200-4r Governor Replacement
Old Mar 28, 2013 | 07:05 AM
67w30's Avatar
I'm replacing the Governor on my 200-4r that was sent to me by Bowtie Overdrives in order to increase my WOT upshifts from 3500 rpm to a higher rpm. My question is, are there any gaskets other than the pan gasket that I will need? Bowtie only sent me the governor and I cannot find any posts or links to a gasket or removal/installation of the governer.
Any help would greatly be appriciated, thanks.
Old Mar 28, 2013 | 08:44 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Yes there is a gasket. If your gentile you can reuse it. Make sure the square cut Oring is installed on the shaft closest to the weights. The gaskets less than $2. I don't remember if anything else needs to be removed other than the Gov housing to R&R the gasket? Also inspect the speedo gear for wear & cracks replace as needed. Any good trans shop should have the gasket on the shelf and can answer the question.
tmaleck
Oct 22, 2013 08:32 AM
yankees
Sep 17, 2012 03:18 PM
yeahbuddy
Aug 17, 2010 12:47 AM
Olds64
Jan 29, 2008 06:17 AM
J-(Chicago)
Drivetrain/Differentials
Dec 11, 2007 07:08 PM
