2-Speed (3-Stage) Jetaway Trans?
My 64 330 F-85 has the Jetaway trans that works flawlessly. However I have given up on chasing fluid leaks. After investing $300 to have all the gaskets and seals replaced, I still get drips. Now I just lay down puppy training pads that catch and absorb the drippings. But I am open to any suggestions that might be of help. Incidently, those training pads work great at catching any form of fluid leak and actually freshen the air in a garage. I thought of inventing a full size catch pad but I am sure that it would never fly due to EPA disposable issues. Thanks!
Appears leaking from the frontal area. Around speedometer cable seal which was supposively replaced.. Should trans go out, I will go with either one of the R's or TH-350. I understand the Jetaway (Turbine 300), although limited by 2 gears, has much less para-power loss than the just mentioned. Thanks again.
dabull55
September 1st, 2013 08:22 AM
TECH9TWISTA
February 12th, 2007 10:58 PM
