2 flywheels-which one 62 Cutlass 215v8
Old Aug 12, 2009 | 02:34 PM
trackz man's Avatar
I am picking up a motor that I purchased off of Craigslist and we have a dilema- There are two flywheels sitting on the ground next to the motor and we are not sure which one is the correct one for the 215 Olds engine. One of them has about 4-5 springs in a circular pattern from the center and the other one has no springs whatso-ever- Please help......
Thanks- Doug
Old Aug 12, 2009 | 06:05 PM
Thanks- Doug
Uh, which one bolts to the crank flange?
Do your really mean "flywheel"? I've never seen a flywheel with springs.
Old Aug 12, 2009 | 09:55 PM
Bluevista's Avatar
Registered
Almost sounds like a clutch disc? Some have the coil springs spaced around the middle and some don't. The discs that don't are usually more for high performance street applications or racing.
Here's an article with I.D. info on the flywheels, really good tips too.
http://www.britishv8.org/Articles/GM-215-Flywheels.htm
This is just a pic of a clutch disc and pressure plate, not for a 215, just for example.
http://www.supercarsunlimited.com/It...CategoryID=258
Old Aug 13, 2009 | 10:54 AM
trackz man's Avatar
After further looking at the two flywheels? they were both so rusted, that we can see marks where the clutch disc has made facing marks on the flywheel, the correct one for the auto trans has no springs in it...
WTony
Dec 16, 2012 11:56 AM
L69
Aug 24, 2012 08:38 PM
slodat
Sep 19, 2010 10:09 PM
1k442
May 4, 2010 10:58 AM
