1983 Delta 88 transmission leaking
Old Yesterday | 09:04 PM
DeltaDude88's Avatar
Hello everyone. My transmission is leaking and I'm not sure from where. I replaced the pan gasket today but that wasn't the issue. There is a steady stream coming from between the bell housing and the transmission pan. I've attached a photo. Any suggestions would be helpful and appreciated. I plan on dropping the transmission but are there options I can try before doing that?
Old Yesterday | 09:17 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It is probably the torque converter seal. There is a chance of the pump o ring but those don't leak very often.
Old Today | 06:36 AM
Unfortunately the front seal on these transmissions can walk out, causing a leak like this. The trans needs to be removed from the engine to access it. There are retrofit retainers to help keep the new seal in place.
1972code26
Jul 6, 2025 05:40 PM
frmrocket
Feb 10, 2019 07:38 AM
scooter123
32
Dec 31, 2013 06:34 PM
nh4kidsdad
Feb 5, 2009 11:34 AM
ztim
Oct 7, 2006 02:20 PM
