1977 T50 replacement options
Old Feb 10, 2026 | 03:06 PM
JPinAZ's Avatar
It has been awhile since I have been here. Back in 2020 you all helped me do a 260-455 swap in a 1977 442. I turned out great! original owner has been driving it with the T50. I have the opportunity to get the car but I know I will scatter the T50. Does anyone know of a straight forward upgrade for the transmission? I do not have specs on the motor but it is a 455 aluminum head 9-1 compression. I was hoping for a simple muncie swap. After that it gets really expensive. Rear gear will need to be changed too. TIA John
https://classicoldsmobile.com/forums...-442-a-148982/
https://classicoldsmobile.com/forums...7-done-158016/
Old Feb 10, 2026 | 03:31 PM
v8al's Avatar
Registered Olds Owner
You have two choices - New or used.
You can pickup a used Borg Warner Super T-10 or a Muncie for under a $1000. Bad news is that it will probably need a rebuild. Figure another $500 for a good basic rebuild kit, more if you need to replace gears. You'll save money if you rebuild it your self. If you go this route you'll need a new shifter also.
New, I'd recommend the TKX.- about 3K from Summit.
You will have to confirm if the T50 bell housing is compatible with the Muncie/T10/TKX bolt pattern. If it isn't you should be able to find a 4spd BOP bell housing.
In either case while your in there you should replaces clutch, pressure plate and throw-out bearing.
Also you'll need to compare the current T50 shifter location to the above choices. The TKX gives you the most options with the ability to move the shifter to different locations.
Unless you can find someone who can confirm this conversion, you should assume that some minor or major floor/tunnel surgery may be required.
The drive shaft may also have to be changed - longer or shorter. At a minimum you'll probably need a new yoke.
Old Feb 10, 2026 | 03:37 PM
JPinAZ's Avatar
Thanks for the reply. Pretty much what I expected. TKX would be sweet!
Old Feb 11, 2026 | 06:06 AM
Nothing is a bolt-in replacement. If you ever plan to use that 455 (and if not, why have it), a TKX is probably the easiest swap.
Old Feb 11, 2026 | 01:39 PM
brownbomber77's Avatar
You can use a Camaro t-5. The shifter location is 1.2" further back than the T50. You'd use the bellhousing from a chevy V8 and then the accompanying trans (muncie or tremec bolt pattern). With that said....don't do it. There's a reason Ford and Chevy didn't put these behind anything larger than their 5 liter cars.
TKX Is your least expensive answer unless you like swapping $400 used transmissions every year. Even built ones won't last behind the torque of a 455 and the weight of a cutlass.
Old Mar 20, 2026 | 04:59 PM
JPinAZ's Avatar
Done! Driveshaft was the only modification needed. Thanks for the input.
oldaman
Jan 25, 2022 07:11 AM
zeeke
Site Suggestions
Jun 1, 2020 07:39 AM
t_huth21
Jun 5, 2014 04:39 PM
nonhog
Sep 19, 2011 08:33 AM
1964f-85
Mar 26, 2009 02:15 PM
